SailNet Community - View Single Post - Propeller Shaft Log
post #9 of Old 11-20-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Propeller Shaft Log
Stuffing boxes do not usually fail catastrophically but if you don't know when it was last re-done and it is warning you now (eg., not dripping but pouring) it is time to replace the packing. Packing is cheap, ~ $25.
Start spraying a penetrant like PB Blaster, or ATF on the nuts now and allow to it sit for a while, days even. The nuts will move eventually with the right tools and lubrication.
A very temporary fix would be to stem the leak from where the shaft exits the boat on the outside (underwater) using candle wax, Butly tape or whatever works.
G'luck.
Everybody has one:
CalebD is online now
