SailNet Community - View Single Post - Troubles with Bukh
post #2 of Old 11-20-2012
klem
Re: Troubles with Bukh
Have you tried running with the filler cap removed for your fuel tank? If you vent is plugged, you will get symptoms like you describe.
Two pieces of data that would be really helpful are coolant temp (I assume that you have a gauge?) and fuel pressure (you probably don't have a gauge but they are not very hard to temporarily put one on).
klem is offline
