SailNet Community - View Single Post - HMS Bounty in trouble...
post #843 of Old 11-21-2012
Minnewaska
Re: HMS Bounty in trouble...
Originally Posted by casey1999 View Post
Note those survival times (as stated in the presentation) are in "good" conditions. At night with high winds, waves, and spray, the survival times should be reduced by quite a bit. Also the survival times as stated in the presentation should be reduced by 30% if you are not just floating motionless. In high seas you would probably be moving quite a bit just to get clear air.
Good points. I did say, depending on conditions.
However, you may drown from exhaustion in 80 deg water in two hours, but its pretty unlikely to be from hypothermia that quickly.
Jeanneau 54DS
Minnewaska is offline
