Zanshin if you are talking about out of the way areas not visible in cainets and drawer areas just break the sharp cut factory edge with sand paper and get some cheap urethane and give it a coat or two. just use it liberally on the edges so it will soak in well, if you are concerned with moisture absorbsion in those areas. you can even use sanding sealer if you want.
regards mike
