SailNet Community - View Single Post - Home made rudder for Catalina 22
post #7 of Old 11-21-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Home made rudder for Catalina 22
Seems that you followed all the best practices when making your rudder. I hope it lasts a long time.
Originally Posted by sevseasail View Post
Thanks for your reply!!
I did coat the rudder with one layer of glass mat plus another layer about 1ft over and under the water line, also it has two coats of epoxy resin, 4 coats of 2 part epoxy barrier coat and 3 coats of bottom paint; I trust this will help keep the interior filler and core dry, also I per-drilled the holes for the hardware bolts with 7/8" bit, filled with epoxy and re-drilled with the correct size bit to prevent water getting into the core via the hardware bolts (that was the problem with the original one). I figure it's not perfect, but, after seeing how catalina built the original, I can assure you this one should last at least as long as the original lasted; so about 12 hrs of labor for 30 yr of rudder is not too bad.
Everybody has one:
CalebD is offline
