Re: Freshwater system for sailboat
Your boat originally had a 5 gallon collapsable plastic water jug (
) that can be purchased at any camping store. The sink drains directly to a thru-hull just above the water line. Its a very simple but operable system. It is also quiet easy to install a fresh water powered system similar to the one you have in your camper if you want to go that route. You can find a lot of info on your Venture here:
Ask A Macgregor Owner - SailboatOwners.com
and here:
MacGregorSailors.com
Good luck with your mods!
“If you surrender to the wind, you can ride it.” – Toni Morrison
"Sic gorgiamus allos subjectatos nunc"
Follow Chameleon's travels at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
