SailNet Community - View Single Post - Installing Additional Keel Bolts
post #4 of Old 11-23-2012
overbored
overbored's Avatar
Re: Installing Additional Keel Bolts
if you are trying prevent or eliminate the Catalina smile then use the kit from Catalina direct. the kit does work well and is a tested method but must be done out of the water so the boats weight is pushing the smile closed before you drive in the lag bolts. the lags will not close the smile with the weight of the keel hanging
"GOLD RUSH" PRINDLE 16
overbored is online now
