Starwind Owners
I had the boat lifted up and we could see most of the area the center board retracts into . I understand the best way to change the center board line is to anchor in 3 feet water and and the board will drop down enough, tie the new line tothe old line.
, go underthe boat and feel for the old line ,it goes thru a hole in the center board, pull your new line thru and tie a knot in the end, and pull the center board up, the hole is at the top and at the rear all that holds it is a knotin the line . my board is solid fiberglass weighs adout 40 lbs and being all fiberglass should never give any problem
