SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #484 of Old 11-25-2012
willyd
美國佬
willyd's Avatar
Re: Low buck projects- Let's see 'em!
My boat came with a heavy-duty Garelick Eez-in outboard motor bracket that was mounted to a custom-made wooden base on the transom. Unfortunately, the Garelick bracket didn't put any of the long-shaft outboards I tried low enough in the water, and couldn't be adjusted further. I sold the Garelick and devised this mount from two aluminum L-shaped pieces and two square sheets, a surplus wooden bracket, and some stainless bolts and screws. I had to cut the inner edge of the square aluminum pieces at an angle so that the motor sat lower in the water.
1964 Whitby 25
Severna Park, Maryland
willyd is offline
