SailNet Community - View Single Post - Jeanneau Attalia
post #128 of Old 11-25-2012
JensK
JensK's Avatar
Re: Jeanneau Attalia
Dear Waymar
I was just through this in the spring. I only removed the loose parts of the barrier coat on the keel, visible through cracks or rust. When shining metal appears on the keel, you are done. Rinse with acetone. Then the first two layers of barrier coat. I used VC-TAR2, because I use VC 17 as fairing. Do this in sections, so that new rust does not get formed while you are working your way round. Then a good deal of West expoxy filling. Then 8 more coatings of barrier on the keel, five layers on the hull.
It sounds easy, but it is a lot of work. The look is highly rewarding, though.
Best regards
Jens
JensK
Sailing in Denmark
Jeanneau Attalia
1986
31 feet
JensK is offline
