SailNet Community - View Single Post - Diesel Fireplace
post #10 of Old 11-26-2012
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Re: Diesel Fireplace
It's hard to tell from you pics, but it looks like there is some sort of thermocouple unit wired into the valve assembly. Its function is to stop the fuel from flowing if the flame goes out for some reason. If it does have a thermocouple, the symptoms you describe sound like that is you problem. The thermocouple has to be hot for the valve to stay open. Your priming button over-rides the thermocouple interlock and lets enough fuel into the combustion chamber to get things going. Once it's hot the interlock should let the fuel flow at whatever rate the meter is set. But, if the thermocouple is bad, once you stop pushing the button the valve closes and that's that. If it still won't work even if the thermocouple tip is good and hot then you can change the thermocouple you'll probably be golden. Finding the right thermocouple might be a problem, however.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
