post #3412 of Old 11-30-2012 Thread Starter
Blue Jacket 40
Paulo have you posted yet on the Blue Jacket 40?
Blue Jacket 40 (BJ40) Performance Sailing Yacht | BlueJacketYachts.com
Yes, about two months ago. I well repost for you.
Big surprise: Island packet is going to launch a series of performance cruisers. They will be called Blue Jacket line and will be designed by Tim Jackett (ex-President and Chief Designer at Tartan and C&C) in collaboration with Bob Johnson (CEO and Chief Designer at Island Packet).
The first one is already on its way to production and even if in what regards cabin design I find the boat too classic, not to say old fashioned, in what regards hull design and technical characteristics I love the boat.
Well, the keel could be more modern and efficient (it is similar to the one on my boat) but in what regards all the rest it looks perfect to me. In fact it is very close to the Comet 41s in what regards weight, ballast and hull design. It fits on the Italian way of looking to performance cruisers.
A relatively narrow boat with a good B/D a deep draft (2.30) and a big stability that is the opposite in design conception of the also new Tartan(and the CC121). I like a lot more this one.
Well, there are some things I don’t like: The traveler over the cabin and only one winch on each side of the cockpit that will have to be used for the mainsail and the genoa, but I believe that could be changed if clients ask otherwise.
Technical Characteristics
LOA: 39’ 10” (12.14 m)
LWL: 35’ 0” (10.67 m)
BEAM: 12’ 4” (3.76 m)
DRAFT: 7’ 5” (2.29 m) deep
5’ 2” (1.56 m) shoal
DISP: 16, 500 lbs (7,484 kg)
BALLAST: 6, 100 lbs (2,767 kg) deep
SAIL AREA: 883 sq ft (82.03 sq m) (100% FT)
MAST HEIGHT: 62’ 6” (19.05 m)
POWER: 40 HP (30 kW)
FUEL: 40 US gal (151 l)
WATER: 110 US gal (417 l)
WASTE: 25 US gal (80 l)
SA/D: 21.8
D/L: 172
DESIGNER: Tim Jackett w/Bob Johnson, N.A.
They say about the boat:
Sailplan and rig:
The large sailplan is a further refinement of the Solent style rig featuring standard double head sails with a working jib and a lightweight 150% reacher that mounts on the integral bow prod, both furled with HarkenŽ systems. The working jib is fitted with a carbon fiber Hoyt BoomŽ that is self-tending and improves performance with its close sheeting and self-vanging feature while the large reacher boosts performance in light air or when off the wind. The fully battened mainsail is equipped with a standard electric halyard winch and a low friction Battcar system and drops easily into a carbon fiber pocket boom with an integral cover and lazy jack system.
This easily managed rig has ample horsepower and versatility for optimizing performance in a wide range of conditions. All sheets lead to the cockpit near the helm and primary winches for short-handed convenience.
On deck:
On deck, anchor handling has been simplified and made especially convenient with a cleverly designed roller recessed in the bow prod providing secure stowage of the anchor and directing the rode to the anchor locker with a (optional) below deck electric windlass that keeps the deck and profile uncluttered. A deck hatch gives access to this area. Wide side decks with full length raised bulwarks, double lifelines, bow and stern rails and cabin top handrails provide security on deck.
The large cockpit has deep coamings, long seats and twin helm stations with great visibility and ready access to all sail control lines. Seat hatches provide access to storage areas and a (optional) central drop-leaf table makes for a great social area. Hinged transom doors open to the integral stern platform with a retractable swim ladder under a central hatch.
Materials used:
The Blue Jacket’s hull and deck are made with a state of the art vacuum infusion process utilizing 100% vinylester resin, quadraxial knitted E-glass reinforcements and a structural foam core. The end result is superior strength and stiffness with significantly reduced weight compared to conventional laminates. …
The use of premium structural foam coring produces better interlaminar bond properties with freedom from potential core deterioration compared to other choices and allows for an industry-best extended hull and deck warranty.
http://www.bluejacketyachts.com/
