SailNet Community - View Single Post - Spirit 6.5/23 Boom Vang/Jack
post #10 of Old 11-30-2012
Re: Spirit 6.5/23 Boom Vang/Jack
I have the same set up as pictured, minus the vang bail, which I think someone added to yours. I believe both the pop top and the vang connect to the slide hence the 2 holes. If so, the closed top will keep the vang down and when you release the top, you can use the vang to hold the top up, at least till you can set slide stop.
jbcsailor is offline
