SailNet Community - View Single Post - Charging batteries with engine while sailing
post #13 of Old 12-02-2012 Thread Starter
brokesailor
SV Skalliwag #141
brokesailor's Avatar
The point of my question was: say a boat does 7 kts with the engine at cruising rpm. Now you are sailing at 7 kts. If you need to run the engine to charge the batteries and you put the engine in gear at cruising rpms (with the boat still under sai) does that put any stress on the drive shaft/transmission or engine?
brokesailor is offline
