SailNet Community - View Single Post - Charging batteries with engine while sailing
post #18 of Old 12-02-2012
hellosailor
Re: Charging batteries with engine while sailing
If the engine must be run in gear (depends on the transmission type) and the boat is exceeding maximum motoring speed...odds are you are surfing because anything like normal hull speed should be witin engine rpm range.
So I'd run the engine at an appropriate high speed, in or out of gear per the tranny's requirements.
Then there's the idea of running the engine at low speed to charge the batteries. WRONG! Let's say the engine has an idle speed around 800 rpm and a cruising speed around 2600 rpm. If the alternator was properly matched up (pulley size & output curve) then the alternator will not be putting out signficant power at low rpms. At 1000 rpm it may be putting out 20-25 of the rated power, at 2000 spm it may be closer to 85% of the rated power. (Numbers drawn from a hat but good enough for examples.)
You need to know how the system has been designed, or have an ammeter in circuit to see what the alternator is putting out, because they are usually designed to put out something near rated power at something near typical cruising rpm, and all you are doing at lower rpm is wasting fuel.
Part of this is cheap and sloppy design (who notices?) and part of this is money, because an alternator that can put out full power at low rpms costs more. And an alternator that can put out full power at low rpms while also not burning out at sustained high rpms (i.e. trying to claw off a lee shore for eight hours) is more expensive again.
hellosailor is offline
