SailNet Community - View Single Post - Charging batteries with engine while sailing
post #24 of Old 12-04-2012
casey1999
casey1999's Avatar
Re: Charging batteries with engine while sailing
Originally Posted by jrd22 View Post
tib- most marine engines are OK at normal heel angles of up to about 15 degrees IIRC.
One thing to consider is the fuel pickup location if you are running the engine while sailing, especially if you have two outboard tanks and only one pickup tube. I made the mistake of starting the engine while heeled over to starboard and sucked air out of the port pickup tube because the fuel had drained through the transfer hose to the starboard tank. I have separate pickup tubes and the tanks are not connected now:-))
Good point. I overheated my engine once (lucky no damage done, cooled it down when high temp alarm sounded) when the boat was sailing in high wind and heeled over. The sea water intake was on the high side of the boat hull and out of the water at times due to large waves.
casey1999 is offline
