SailNet Community - View Single Post - Running Rigging Vendor_Whos Best?
post #10 of Old 12-04-2012
peterchech
Re: Running Rigging Vendor_Whos Best?
Ditto all the above, rigging only is extremely helpful and will literally downsell you if it's in your best interest. Defender and Mauri pro sailing are great. I recently had a bad experience with Sound Boatworks, where I ordered a jacket they had on special and promised it would be shipped that day or the next one (I had a turkey day regatta I wanted it for). Almost 3 weeks later they still hadn't even shipped it. Mauri pro and defender ship same or next day, so I was a little spoiled I guess. I cancelled and ordered from Mauri pro who had the same promotion ongoing.
Splicing amsteel is very easy once you do it a couple times (great tutorial onlinea here:
) and requires little more than a marlinspike and some tape. If you are using high tech cored lines with poly covers then you simply splice the core which like I said is very simple. However if it is standard polyester core with polyester cover, then the cover takes the load and the more difficult double splice is necessary.
peterchech is offline
