Re: Charging batteries with engine while sailing
I apoligize for my mistake...I think the Kanzaki transmissions are ok to run while in neutral when the engine is not running. Its the Hurth zr which is not.
I have always sailed with it in reverse because i dont like it spinning or the rumbling noise and worried about the tyranmission being properly lubed.. Apparently I should only sail with it in neutral.
Live and learn
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
