SailNet Community - View Single Post - Main Halyards - Back to cockpit or keep at mast?
post #21 of Old 12-06-2012
goboatingnow
Nearly an Old Salt
Re: Main Halyards - Back to cockpit or keep at mast?
If you can reef successfully from the cockpit with out having to then inspect the reef at the mast, then bring it back , it is an advantage. But Ive seen too many reefing systems that ultimately need a trip to the gooseneck to sort out the reef. In that case leave everthing at the mast.
For example, if you have a conventional reefing system with a rams horn, then theres no point in cockpit reefing lines,
even with single line reefing, I find often you cant see if the tack cringle has got pulled down properly, especially at night on a reach , where you cant see the other side of teh sail, often this means a trip to the mast, which undoes all the advantages of in cockpit reefing ( and in that respect I am more a fan of double line reefing)
SO the answer is " it depends"
goboatingnow is offline
