SailNet Community - View Single Post - Course to steer at a given speed.
post #3 of Old 12-06-2012
Capt. Gary Randall
Capt. Gary Randall's Avatar
Re: Course to steer at a given speed.
Magnetic observations made by explorers in subsequent decades showed however that these suggestions were true. But it took until the early nineteenth century, to pinpoint the magnetic north pole somewhere in Arctic Canada (78° N , 104° W). From then on the angle between the true North and the Magnetic North could be precisely corrected for. This correction angle is called magnetic variation or declination.
It is believed that the Earth's magnetic field is produced by electrical currents that originate in the hot, liquid, outer core of the rotating Earth. The flow of electric currents in this core is continually changing, so the magnetic field produced by those currents also changes. This means that at the surface of the Earth, both the strength and direction of the magnetic field will vary over the years. This gradual change is called the secular variation of the magnetic field. Therefore, variation changes not only with the location of a vessel on the earth but also varies in time.
The correction for magnetic variation for your location is shown on the nearest! nautical chart's compass rose. In this example we find a variation of 4° 15' W in 2009, with an indicated annual correction of 0° 08' E. Hence, in 2011 this variation is estimated to be 3° 59', almost 4° West. This means that if we sail 90° on the chart (the true course), the compass would read 94°.
Another example: let's say the compass rose gives a variation of 2° 50' E in 2007, with a correction of 0° 04' E per year. In 2009 this variation is estimated to be 2° 58', almost 3° East. Now, if we sail 90° on the chart, the compass would read 87°.
Correcting for variation
These overlayed compass roses show the difference between true north and magnetic north when the magnetic variation is 10° West.
From the image we find: tc = cc + var
in which “cc” and “tc” stand for “compass course” and “true course”, respectively.
To convert a true course into a compass course we need first assign a “-” to a Western and a “+” to a Eastern variation. Note that this makes sense! because of the clockwise direction of the compass rose. Here, the inner circle is turned 10° anticlockwise, hence -10°.
Now, use the same but re-written equation:
cc = tc - var
235° = 225° - (-10°)
So, to sail a true course of 225°, the helmsman has to steer a compass course of 235°.
To convert a compass course into a true course we can use the original equation. If we have steered a compass course of 200°, we have to plot a true course of 203° in the chart if the variation is 3° East or a true course of 190° if the variation is 10° West.
Magnetic deviation
Magnetic deviation is the second correctable error. The deviation error is caused by magnetic forces within your particular boat. Pieces of metal, such as an engine or an anchor, can cause magnetic forces. And also stereo and other electric equipment or wiring, if too close to the compass, introduce errors in compass heading.
Furthermore, the deviation changes with the ship's heading, resulting in a deviation table as shown below. The vertical axis states the correction in degrees West or East, where East is again positive.
The horizontal axis states the ship's heading in degrees divided by ten. Thus, when you sail a compass course of 220°, the deviation is 4° W. (Note, that on most modern sailing yachts the deviation is usually not larger than 3°).
When a compass is newly installed it often shows larger deviations than this and needs compensation by carefully placing small magnets around the compass. It is the remaining error that is shown in your deviation table.
You can check your table every now and then by placing your boat in the line of a pair of leading lights and turning her 360 degrees.
Correcting for both deviation and variation
Converting a compass course into a true course, we can still use our equation but we need to add the correction for deviation:
cc + var + dev = tc
Example 1: The compass course is 330°, the deviation is +3° (table) and the variation is +3° (chart);
330° cc + 3° var + 3° dev = ?° tc
giving a true course of 336° which we can plot in our chart
Example 2: The compass course is 220°, the deviation is -4° (table) and the variation is still +3° (chart).
220° cc + 3° var + -4° dev = ?° tc
giving a true course of 219°.
Example 3: The compass course is still 220°, therefore the deviation is still -4° (table) but let's use a variation of -10° this time.
220° cc + -10° var + -4° dev = ?° tc
giving a true course of 206°.
Converting a true course into a compass course is a little less straight forward, but it is still done with the same equation.
Example 4: The true course from the chart is 305° and the variation is +3° (chart), yet we don't know the deviation;
?° cc + 3° var + ?° dev = 305° tc
Luckily, we can rewrite this so this reads:
cc + dev = 305° tc - + 3° var = 302°
In plain English: the difference between the true course and the variation (305 - + 3) = 302 should also be the summation of the compass course and the deviation. So, we can tell our helms person to steer 300°, since with a cc of 300° we have a deviation of +2° (As can be deduced from the deviation table above).
Example 5: The true course from the chart is 150° and we have a Western variation of 7 degrees (-7°). We will use the rewritten equation to get:
150° tc - - 7° var = cc + dev = 157°
From the deviation table we find a compass course of 160° with a deviation of -3°.
Voilą!
Magnetic course
© sailingissues.com
The magnetic course (mc) is the heading after magnetic variation has been considered, but without compensation for magnetic deviation. This means that we are dealing with the rewritten equation from above:
tc - var = cc + dev = mc.
Magnetic courses are used for three reasons:
To convert a true course into a compass course like we saw in the last paragraph.
On vessels with more than one steering compass, also more deviation tables are in use; hence only a magnetic or true course is plotted in the chart.
Bearings taken with a handheld compass often don't require a correction for deviation, and are therefore useful to plot in the chart as magnetic courses.
Note, that the actual course lines the navigator draws in the chart are always true courses! These can subsequently be labeled with the true course or the corresponding magnetic or compass course if appropriate. In the next chapter we will be plotting courses in the chart.
To summarise, we have three types of “north” (true, magnetic and compass north) like we have three types of courses: tc, mc and cc. All these are related by deviation and variation.
Glossary
Maps with isogonic lines:
World - overview 2000
World - detailed 2000
World - detailed 2005
World - animated in timeVariation: The angle between the magnetic north pole and the geographic north pole. Also called the magnetic declination.
Secular variation: The change of magnetic declination in time with respect to both strength and direction of its magnetic field.
West (-) , East (+): Western variations or deviations are designated with a negative sign by convention due to the compass card's clockwise direction.
Deviation: The error in compass heading caused by electric magnetic currents and or metal objects.
Deviation table: A table containing deviations in degrees versus the ship's heading (compass course) in degrees. Usually plotted in a graph.
True course: Course plotted in the chart i.e. course over the ground or “course made good”. The course corrected for compass errors.
Compass course: The course (ship's heading) without the correction for compass errors.
cc + var + dev = tc: This equation shows the connection between the compass course, its errors and the true course. It can also be read as: tc - var = cc + dev.
Use the logo to navigate through this course,
...or go to the next chapter,
or download the complete navigation course as PDF - including practice materials, exercises and answers.
Register E-mail:
Tell a friend E-mail:
Search
Books·chartsSitemap|A-ZContactRSS|CharterguidePDFs
Charter guide
Yacht charters
Greece
Turkey
Dolphins
Chapters:
3 2 1
6 5 4
9 8 7
10
5 May 2012
© 2000 – 2012 Diederik Willemsen |
Site map | A-Z index |
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
