SailNet Community - View Single Post - methods of recovering a morgan 25 1967
post #6 of Old 12-07-2012
Southron Spirit
Re: methods of recovering a morgan 25 1967
i just saw on discovery channel where some guys moved a log cabin several miles using logs as rollers .
i have moved a 6'x14' shed across my property using 2" pvc rollers and a pick up truck to drag it . you could use a hose to connected to pvc tube to wash out the ground enough to slide the rollers under .
check with a farm supply store for round fence posts as rollers
i would get a couple of nylon tow straps and anchor it in place so it cant slide down hill while you get it on the rollers .. have you inspected the down side for damage from the inside ?
southern cross
ct-34
Southron Spirit is offline
