The only thing I don't particularly like about the
drysuits is that, as mentioned above, they do have tight openings. The neck opening particularly, if cut so it's really watertight, is very uncomfortable. It's like having a rubber band around your neck. Every time I've worn mine, it's a relief to get it off. They come with very small diameter openings. Unless you have a very small neck, wrists and ankles, they require careful cutting (directions come with the suit). They are certainly NOT one size fits all. The neck and sleeve rubber
can be renovated when it wears out. Keeping them from drying out is the same as for any wetsuit or rubber product. The prices on these things has really skyrocketed as has any Goretex product.
