SailNet Community - View Single Post - Still holding its own - HF Radio
post #20 of Old 12-10-2012
Re: Still holding its own - HF Radio
I chatted with the maker of the KISS, and found him to be very helpful. You can tell from the way he runs his company, that he really believes in his product and was very responsive to questions.
My question to him was similar to SimonV's question. The response I got back was you only have to hook up the KISS to the tuner, and don't need to run foil between the transceiver and tuner, or connect anything by foil to any ground. As the manufacturer of the KISS pointed out, on the ICOM M802 the tuner and the transceiver are already connected via the control cable and there is no reason to ground everything using foil. I was a skeptic, but gave it a try and it did work. And very well at that.
windward54 is offline
