SailNet Community - View Single Post - Can you run your engine without a water intake
post #8 of Old 12-12-2012
jrd22
Courtney the Dancer
jrd22's Avatar
Re: Can you run your engine without a water intake
Just open up your raw water strainer, with the seacock closed, and run a hose into it while running the engine. Do NOT hook up a garden hose directly to the hose that feeds the raw water pump, you don't want pressure to the suction side. Your exhaust will flow out the through hull like normal.
Running the engine once a month is a very good idea.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
