SailNet Community - View Single Post - Fuel line shut off options?
post #2 of Old 12-13-2012
overbored
overbored's Avatar
Re: Fuel line shut off options?
you don't need a three way to have a bypass. just a tee fitting on both sides of the solenoid and you can use the shutoff valve you have between the tees. if the hand valve is open the fuel will bypass the solenoid.
"GOLD RUSH" PRINDLE 16
overbored is offline
