SailNet Community - View Single Post - overpropped vs underpropped
post #6 of Old 12-14-2012
lancelot9898
Re: overpropped vs underpropped
I too have a max prop and a 4-108 Perkins that has a max continuous rating of 3600 rpm. One thing you need to check is the calibration of the tach using a photo tack. I found that mine was off quite a bit.
The standard wisdom is to set that pitch so that you can achieve that rpm rating at WOT.....I have not followed that wisdom and not suggesting that you follow what I did. I'm just relating what I have done. After changing that pitch and seeing how the boat performed under various setting(it's a 37 ft Tayana), I decided on a pitch that let me cruise at 6 knots at 80% of WOT. However note that my WOT is only 3000 and not the 3600 ....The only thing IMHO that I'm doing is not achieving the max hp that is available if I could go to the 3600rpm. I fail to see how that I'm lugging the engine or glazing the cylinders. I could be wrong, but I've been doing this since the engine was new back in 1985 putting an average of 60 hours per year for the past 28 years.
lancelot9898 is offline
