SailNet Community - View Single Post - what type battery and size are you using on your spirit
post #11 of Old 12-14-2012
windyway
windyway's Avatar
Location: West coast lower mainland British Columbia, Canada
Re: what type battery and size are you using on your spirit
Originally Posted by Southron Spirit View Post
great pics thanks , how are you securing the base to the hull ?
how do you like those bilge hoses ?
where are you calling the deepest part of the bilge?
i thought it would be under the cockpit by the companion way .
how about a picture of your bilge pump set up , i am fixing to install two pumps permenatly inplace
1) The wedge shaped pieces are permanently glassed into the hull with 3 coats of fiberglass, & the battery shelf itself is screwed into them with 5 stainless countersunk screws.
2) This post is for batteries. Bilge pumps are in the mod section you should look around, it might be interesting.
3) See item 2.
windyway is offline
