SailNet Community - View Single Post - overpropped vs underpropped
post #15 of Old 12-15-2012
jrd22
Courtney the Dancer
jrd22's Avatar
Re: overpropped vs underpropped
Kelly- what is your engine manufacturers spec for WOT. Full governed rpm is the rpm at full throttle in neutral, the governor controls the maximum rpm to prevent damage to the engine. If you were able to reach the max governed speed under load you were either way underpropped, or you have a lot of hp. Sounds like by increasing pitch you actually put the engine under load which would make a difference in sound.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
