post #3504 of Old 12-16-2012 Thread Starter
Vendee Globe
This guys are all great sailors. Just look at this story With mike:
Almost to the day four years, and within three hundred miles or so of the same spot that he lost his mast in the last Vendée Globe, Mike Golding has emerged this morning from a problematic incident which, but for the actions of the highly experienced skipper, could have been much worse.
"There was certainly a point where I thought, 'Here we go again, please, not another Christmas in Perth'," Golding said. "But I am reasonably sorted now, I am not going to go mad. ...
It was around 0400hrs this morning when Golding was just completing a sail change, hooking south into stronger breeze, when the furling line on the giant Code Zero failed just as a 35kt squall hit. Previously the wind had been around 18kts. With the boat overpowered and the headsail flogging wildly with no way of re-furling, the autopilot let go. Quick thinking Golding reached for the keel dump and effectively set Gamesa on her side to reduce the pressure on the rig before battling the Code Zero down in a nasty heap.
"I’m back on course now. The Code Zero is a bit of a mess with all the sheets inside it. Im in repair mode now and have to sit and stitch the cover back on the furler line...
"When all this was going on I had the flashback to four years ago. It is so dangerous now because you have 20kts and are lulled into a false sense of security and then suddenly there is a big 35kts gust."
