SailNet Community - View Single Post - Battery Sizing - am I crazy?
post #75 of Old 12-16-2012
sstuller
Re: Battery Sizing - am I crazy?
The one virtue of the 12 volt battery is voltage. You are getting twice the voltage for half the weight. Two 6 volt GC's weigh about 120# for 12 volts while the 12 volt battery is 60#. If you want 24 volts two 12 volt batteries weigh 120 # but you need four GC's at 240# to get 24 volts. Usually sailors worry about weight. Unless you absolutely need the extra capacity from the GC's, 12 volt batteries have the weight advantage. Thanks. Steve S.
sstuller is offline
