Re: Heavy winds?
If you would like some fun try to find an eb6 Pressure density calculator. IMHO You would be at your fastest in cold air, at sea level. in warm salt water. Slow Just the other way around High alt, cold fresh water lake, with a hot wind. Factor in the waves a small shallow body of water means smaller waves this adds speed if the surface turbulance is just right. How much is for an expert looking for a speed record . Most likely on a kite board? Since the Kites are behind. far beyond me. Regards, Lou
