SailNet Community - View Single Post - overpropped vs underpropped
post #37 of Old 12-18-2012
Minnewaska
Re: overpropped vs underpropped
Originally Posted by Brezzin View Post
....Having just replaced my three blade fixed with a four blade feathering. I find that I can only get to 2900rpm with the max WOT at 3200. ....
This is confusing. If your new feathering prop won't allow you to get to max rpm under load, then it needs to be adjusted. If you're uncomfortable at any given speed, just pull the throttle back. But it should be able to get to max rpm.
Jeanneau 54DS
Minnewaska is offline
