Old 12-11-2006
tadds tadds is offline
tadds is on a distinguished road
There is a formula you can use to calculate stability.
The following is the formula used to calculate The Angle of Vanishing Stability:
Screening Stability Value ( SSV ) = ( Beam 2 ) / ( BR * HD * DV 1/3 )
BR: Ballast Ratio ( Keel Weight / Total Weight )
HD: Hull Draft
DV: The Displacement Volume in cubic meters. DV is entered as pounds of displacement on the webpage and converted to cubic meters by the formula:
Displacement Volume in Cubic Meters = ( Weight in Pounds / 64 )*0.0283168
The Beam and Hull Draft in this formula are in meters. These values are entered in feet on the webpage and are converted to meters before SSV calculation.
Angle of Vanishing Stability approximately equals 110 + ( 400 / (SSV-10) )
You can go to the online calculator (along with many more) at:
http://www.sailingusa.info/cal__avs.htm
