SailNet Community - View Single Post - SF Bay Sailors - Transiting the Bonita Channel?
post #14 of Old 12-21-2012
L124C
L124C's Avatar
Re: SF Bay Sailors - Transiting the Bonita Channel?
[quote]
Originally Posted by GeorgeB View Post
I concur with MarkSF, If the NOAA prediction holds true, this is going to be one big, lumpy, left-over sea that you will be transiting. You might not be able to hold a close haul course in the Northerly wind and tacking to Stb will put you over the Potato Patch, which will be real lumpy if we’re talking a general forecast 10 ft and 13 seconds. What time is your return trip? The next storm will roll through on Thursday, and a southerly wind shift could make the return trip a bit more dangerous than normal. Double check the current predictions for under the Gate as an ebb will cause the 13’ waves to stack up even higher. Let us know what you see out there if you go. This Picture is running the Bointa Channel in 10-15’+ waves at around 10 seconds. They were breaking clear across the ‘Patch. We saw one break continuously from the Patch and across Bonita at which point we bailed and went around to the main ship channel. Only to encounter a big one breaking clear across the channel. Be good, be brave.QUOTE]
Is that you George? Great shot, but now you've blown my image of you as Thurston Howel III!
Just as well...he wouldn't have lasted a minute in that swell!
L124C is offline
