Thanks Fryewe,
I guess i'm not enough of a mechanic to figure out how I do what you said though. If the
fuel system is so sensitive to air in it how do I attach a (rubber) squeeze bulb with I guess a rubber tube to a pressurized steel
fuel line without having air leak in from there?
Another question, as I looked back on all the responses so far is, when I took off both filters to replace them there was
fuel in them so I guess that at least rules out a blocked lift
pump in the tank right (my problem started after I had just topped off the
fuel tank)?
Aye's me.
