Old 12-23-2012
Faster Faster is online now
Re: Yanmar 2gm2f no start after fueling
One other nasty I've seen is a perforated pickup tube in the tank.. depending on where it is, you can be fine as long as the fuel in the tank is higher than the pinhole, but once the fuel level drops you're sucking air from there.
Doesn't really match your symptoms, I suppose, but such a problem could be coincidental to your issue. It's another area to check if you have persistent air in the system
