SailNet Community - View Single Post - Yanmar 2gm2f no start after fueling
post #19 of Old 12-23-2012
jrd22
Courtney the Dancer
jrd22's Avatar
Re: Yanmar 2gm2f no start after fueling
Fill the secondary with fuel then try cranking the engine. I've heard that if the cam isn't in the right position the manual fuel pump won't do anything (they're kind of worthless IMO). Crank the engine with the bleed screw open till you get fuel then work your way to the injectors and do each one at least two or three times after the engine is running. It's a lot easier if you have someone to operate the ignition switch for you (obviously) until you get the engine running.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
