SailNet Community - View Single Post - Perkins 4.108M DIY Rebuild -- A Narrative
post #32 of Old 12-27-2012
erps
the pointy end is the bow
erps's Avatar
Re: Perkins 4.108M DIY Rebuild -- A Narrative
Cool!
I needed a new shaft for a Jabsco water pump a couple years ago. I took the old one into a machine shop and had them turn out two for me. A replacement and a spare. I got two shafts for less than a new one from Jabsco. I wonder if you could have a new shaft machined? Also, if you take your parts to a bearing store, they can take measurements and provide you with both bearings and seals based on the dimensions. A person can often get seals and bearings for a fraction of the cost this way, but it takes some patience.
For cleaning up parts for painting, a little sandblaster makes quick work of it. I bought the sandblaster nozzle for $25 then bought a plastic foot locker, but a window hole in the top and screwed in a piece of plexiglass for a viewing port. I cut two holes to stick my arms through and cemented in some PVC couplings so I had something to hose clamp a couple of big rubber gloves to on the inside. For about $50 total, I have a portable sandblaster that I either set up on saw horses or on the bed or the pickup.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
