SailNet Community - View Single Post - Dripless Shaft Seal versus Stuffing Box
post #59 of Old 12-29-2012
dorymate1
Re: Dripless Shaft Seal versus Stuffing Box
For all of you stuck on the traditional packing box. A couple of notes. When packing is continually tightened over time the shaft will be grooved at this point. I have witnessed broken shafts that feel out of boats because of this. It does cause a little more than a drip I promise. Also have seen many log hoses replaced with exhaust/ water hose and rusty clamps that just fall off. No matter witch systems you use always check your shaft log before leaving your vessel will go a long way to piece of mind. When ever you leave a boat always check bilges and listen for running water Then and only then can you continue to lose sleep over her for every reason.
May you weather all storms
dorymate1 is offline
