SailNet Community - View Single Post - Leak at mast wiring deck penetration
post #12 of Old 12-31-2012 Thread Starter
Rusty123
Re: Leak at mast wiring deck penetration
Originally Posted by Alex W View Post
Since my drain hole has been clogged I made a wick that I hooked through the tube that pulled the water down to a pot sitting on the cabin table. This is a hacky fix, but is better than having water on the table and floor. This may be a temporary solution that works for you. I made this wick by taking 3 or 4 feet of 1/8" line, decoring it, and running thin wire (piano wire) up where the core was. The top of this was bent like a paper clip and hooked on the top of that mast step tube.
Thanks for this tip -- would be better than visiting the boat every few days to mop up the floor, as I've been doing.
Rusty123 is offline
