SailNet Community - View Single Post - How much water in the fuel filters is Ok?
post #2 of Old 01-01-2013
jackdale
jackdale's Avatar
Re: How much water in the fuel filters is Ok?
Originally Posted by MarkSF View Post
I just changed both fuel filters on my Universal 5424 (the first is an aftermarket Fram). I got a couple of ml of water amongst the fuel I drained, you can see it at the bottom of the fuel. This is over about 100 hours of use. I'm thinking this is OK but wanted to check with the experts...
Do you have a water separation filter, like a Racor, in your system? It should remove water from the fuel BEFORE it gets to the fuel filter. I would suggest that water in the fuel filter is problematic. The Racor will likely have a glass bulb in which you can see water at the bottom. A valve at the bottom permits the water to be drained.
jackdale is offline
