SailNet Community - View Single Post - How much water in the fuel filters is Ok?
post #5 of Old 01-02-2013
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: How much water in the fuel filters is Ok?
Originally Posted by MarkSF View Post
I don't have a dedicated separator, just the aftermarket Fram, which is just a filter. Better put a Racor separator on my shopping list, then?
Mark--You would be wise to install a Racor FG500 filter:
One can observe water, if any, in the bottom of the bowl and drain it, if necessary, without difficulty. (If you are finding much water, however, it would be wise to have your fuel tank(s) "polished".) Another advantage of this filter is that the turbine/spindel seen through the bottom bowl "spins" the fuel such that heavier debris is thrown out and collects in the bowl as well where it can be flushed out through the bottom drain.
FWIW...
svHyLyte is offline
