SailNet Community - View Single Post - rain water entering bilge thru mast.
post #10 of Old 01-04-2013
L124C
L124C's Avatar
Re: rain water entering bilge thru mast.
Originally Posted by Tempest View Post
Common problem.
Here's one solution: copied from a Fellow Sabre owner
Installing Garboard Drain
Nice job and great documentation, but that's a lot of work, and the less holes in the bottom of my boat the better AFAIC!
As long as the water stays in the bilge, what harm does Ice do? Will it crack the bilge/hull? If so, Couldn't you simply have a space heater in the salon with a thermostat set at 40 degrees?
I know!...Treat your bilge to a pint of Bacardi's 151!
L124C is offline
