SailNet Community - View Single Post - Yanmar 2GM20F mixing elbow Pearson 31-2
post #4 of Old 01-05-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Yanmar 2GM20F mixing elbow Pearson 31-2
Neo,
Looks like both your flange and your elbow are aluminum.
You might want to try applying a little (maybe a lot) of heat to the pipe coupler (your "joint") to try and get the two apart.
As for cleaning out the inside of the mixing elbow: If it is aluminum, you'll need to be careful if you want to try boiling it out. Radiator shops usually have set ups to do this, but make sure you you talk to the owner/foreman and discuss the risk up front.
For DIY, I'd think about letting it soak in Spray Nine for a while first, to see if that helps loosen things up a bit. Carb and/or brake cleaner might also be somewhat effective.
________
'85 BYB Vagabond 39
PorFin is offline
