SailNet Community - View Single Post - best way to mount Aluminium to steel underwater
post #4 of Old 01-05-2013
PorFin
Seņor Member
PorFin's Avatar
Re: best way to mount Aluminium to steel underwater
xymotic:
I think welding a nut onto your hull is overthinking it a bit.
I'd probably be inclined to treat the light as any other below-the-waterline through hull. Pick your location, drill your main and bolt holes, bed the puppy with a liberal amount good sealant, and through bolt it. Since your hull is steel, lock washers and hex nuts should be sufficient.
________
'85 BYB Vagabond 39
PorFin is offline
