SailNet Community - View Single Post - Dangers of LED navigation lights
post #31 of Old 01-07-2013
hellosailor
Re: Dangers of LED navigation lights
tj, if you see a blue solid light, you call the USCG and ask them if there are any military vessels on manuevers in the vicinity. When they say no, you just say thank you, we saw a vessel with a solid blue light and just wanted to make sure.
They should dispatch a response immediately, as blue lights are highly restricted in use. Odds are what you have seen is a green glass nav light that should have had a tungsten bulb in it, but some joker stuck a "white" LED behind it. Bad idea, the LED has to match the color of the lens in order to stand any chance of not being filtered or changed by it.
Considering that an LED steaming light should outlast a conventional one by at least 10x, using an LED steaming light will save you ten inconvenient trips aloft. Worthless? Maybe for some.
And the old post form the OP, that his friend does not use ANY LED nav lights because the white ones might be mistaken for stars? That's just illogical, why should the color of the white ones have anything to do with using the red and green ones? What, he's seen lots of red and green stars too? Again, there will be at least TEN TIMES that you don't have to change that bulb once you've replaced it with LED.
Ten times when you'd have to put down your beer and make a trip to the bulb locker. Hmmmm....
hellosailor is offline
