SailNet Community - View Single Post - Dreadnought 32
Thread: Dreadnought 32
post #24 of Old 01-07-2013
moriahsailing
Re: Dreadnought 32
Hello; I am responding o inquires about a dreadnought 32. I have owned my Dreadnought for 24 years and it has been a good boat and have sailed her about 75,000 miles. Most on a 10 year circumnavigation. Boat was given an etra 500 lbs of ballast by the first owner. It took the space of the deep bilge which is a disadantage so a cycling bilge pump and separating the packing with it`s own separate chamber and pump solved that issue. Ketch rigged I found that by lightening the bow and running a 80 percent jib Moriah ran and beat to weather much better than originally. She was over pressed with a 110 percent very full cut jib. I only use it in very light air`s to 10 knotts running. In 20- 35 knotts running with a small jib and double refed main it is possible to run 135-175 miles per day. Across the Indian ocean from Cocos Keeling to Madagascar we averaged 145 per day. Small jib was the way to go. Far less motion and less work. Mizzen is great in light airs on tack to near broad reach. It is very full cut and 110 sq foot. Main is shorter than most but the lower sale plan is preferable. Storage everywhere. %-6 moths stores for 2 people plus spare parts. Use electric auto pilot. I removed the trim-tab after our first passage to the Marquesas as the was too much wetted area uon the rudder. I wore out 4 in 10 years but it was nice having the same brands for spare parts. Installed mast steps which I was happy to have in a calm or smooth seas. The spreader were a favorite perch at these times. Also to get a line that was lost and check the rigging they were indispesable. The down side was lines would get jammed once in a while. On the second engine the md 17c ram over 10,000 hours. Westerbeak does not look to be as good of engine but so far just minor issues after 3 + years.
Happy Saing Randy Short
S/V Moriah
Newport Beach, Ca
moriahsailing is offline
