SailNet Community - View Single Post - Changing Oil - an easier way?
post #1 of Old 01-09-2013 Thread Starter
tspooner
As I wait for brighter and warmer days I've begun pre-season maintenance and upgrades to my boat. My Yanmar 2GM sits very low in her bilge and although I'm sure there is a drain plug in the oil pan there is no way to locate a container under the pan to contain the drained oil. The boat came with a manual vacuum pump where you insert a tiny (about 3/16") hose through the dipstick hole and stroke for an eternity. I'm never satisfied that I got all the old oil out as the drain hose is quite stiff with a perpetual curl in it and I doubt that the end of it ever really touches the bottom of the pan. Other than draining the oil directly into the bilge and pumping it from there does anyone have any suggestions for a more efficient and cleaner method to extract the used oil. There's gotta be a better way!
tspooner is offline
