SailNet Community - View Single Post - problem diagnosis needed, no speed, smoke, low rpms
post #7 of Old 01-09-2013
lancelot9898
Re: problem diagnosis needed, no speed, smoke, low rpms
My first suspension is that a fishing line may be causing that shaft not to spin properly. However after you dive on the boat and can turn the shaft while in neutral that would rule that out. I too have a max prop and while it has been flawless in the past 25 years of use just as a check make sure that it is rotating properly.
lancelot9898 is offline
