SailNet Community - View Single Post - Full or fin keel?
post #580 of Old 01-09-2013
blt2ski
blt2ski's Avatar
Re: Full or fin keel?
Do not remember which number, be it capsize or comfort ratio, but was not one of them "hood" a naval architect that came up with that ratio. Later said it was good, but at the end of the day with some of the newer designs not as useful as with past designs. Not saying that that ratio should be thrown out per say, as it favors longer/skinnier designs vs some of the fatter hulled designs of today. Rather apparent that hull design will potentially make or break a design depending upon useage as to if it will or will not work for the end user. Not just fin vs full vs bilge vs CB or some combo there of!
The more I type, I believe it is the motion comfort ratio number. Even short will come out on the lower side of things than width. As a 30'L 10' wide boat will come out with a worst number than a 60' x 20', even tho the length.width ratio is equal. I am also recalling disp being part, maybe that needs to be equally doubled to get the same ratio, where is going up double in length, usually (typically) quadruples or equal the disp of the boat. That would be an interesting plug in numbers to see what or if one can get different equal length and beam to equal....
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
